[GRASS-dev] [GRASS GIS] #90: v.parallel: problems with inside corners
GRASS GIS trac at osgeo.org
Tue Mar 11 08:09:58 EDT 2008
 Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  6.4.0
Component:  default  |     Version:  unspecified
 Keywords:           |
 this was bug # over on the old gforge tracker. moving it here.
 http://wald.intevation.org/tracker/index.php?func=detail&aid=390&group_id=21&atid=204
 Hamish
 2007-05-04
 There is a problem with v.segment side-offset parallel line generation for
 inside corners. It is in Vect_line_parallel(), so v.parallel, v.buffer, et
 al. are also affected. See it by doing the "-500" side-offset example in
 the v.segment help page and changing -500 to +500. Or do "v.parallel
 dist=500" using the railroads vector map.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/90>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
