[GRASS-dev] db.connect database= parameter is null
Patton, Eric epatton at nrcan.gc.ca
Wed Mar 12 11:14:38 EDT 2008
I created a new location using today's svn source, and noticed that db.connect doesn't have its database parameter pre-populated with $GISDBASE/$LOCATION_NAME/$MAPSET/dbf as it used to; it is now blank. Possible bug? Would it possible to get the module to at least populate $GISDBASE/$LOCATION_NAME/$MAPSET for this parameter?
~ Eric.
