[GRASS-dev] db.connect database= parameter is null
Martin Landa landa.martin at gmail.com
Wed Mar 12 11:54:22 EDT 2008
anyway if you run some command which calls Vect_default_field_info()
from Vlib, VAR file is created and default driver set up to dbf.
e.g. g.copy vect=
Martin
2008/3/12, Patton, Eric <epatton at nrcan.gc.ca>:
> >Hi,
>  >yes, see
>  >http://trac.osgeo.org/grass/ticket/7
>  >It seems to me that the VAR file should defined for newly created
>  >mapset by default to avoid possible problems.
>  >Martin
> Thanks for the pointer. I'll hardcode my database paths for now.
>  ~ Eric.
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
