[GRASS-dev] Re: [GRASS GIS] #7: Location wizard: should predefine DB connection for new location
Patton, Eric epatton at nrcan.gc.ca
Thu Mar 13 10:40:25 EDT 2008
Eric:
 >> Thanks for the pointer. I'll hardcode my database paths for now.
Hamish:
> see the db.connect help page example for DBF (I usually just cut and
> paste that to the command line when needed). It accepts variable
> LOCATION, MAPSET, you don't need to hardcode it. (Be sure to keep the
> path with $VARIABLES in single quotes!)
Should each of $GISDABSE, $LOCATION_NAME, and $MAPSET have populated values
on location startup? These variables always remain blank for each location that
I try:
~ >echo $GISDBASE
~ >echo $LOCATION_NAME
~ >echo $MAPSET
are these variables only available from the shell if I export `g.gisenv` or eval `g.gisenv`
first?
~ Eric.
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080313/2b7826e3/attachment-0001.bin
