[GRASS-dev] Re: [GRASS GIS] #100: v.surf.rst also crashes on Mac OS X
GRASS GIS trac at osgeo.org
Wed Mar 19 00:16:58 EDT 2008
  Reporter:  cmbarton  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  blocker   |   Milestone:  6.3.0
 Component:  default   |     Version:  unspecified
Resolution:            |    Keywords:
Comment (by cmbarton):
 This is happening with Spearfish and with the new NC dataset. I've simply
 set my region to match the elevation DEM. In the NC dataset, I think this
 is a little over 2million cells. This is not extraordinarily large and it
 IS the demo set for GRASS.
 It is with 10.4 AND with 10.5 for everything except r.random. This is only
 with 10.5.
 I'm also finding that r.resamp.interp says it makes maps, but it does not.
 With the neighbors algorithm, it makes a map that is exactly the raster
 points that are input. That is, there is no interpolation. For bilinear
 and bicubic, it makes NAN maps. I've checked this with r.info. I'll give
 examples below. Note that the output of the nearest routine produces only
 500 points (see r.univar results)--the same number I used as points for
 interpolation. Also note that I just updated from the SVN trunk, did a
 make distclean, and compiled fresh this afternoon.
 Michael
 ---- output from running r.resamp.interp -----
 GRASS 6.3.svn (nc_spm_07):~ > r.info elev500bilinear
  | Layer:    elev500bilinear                Date: Tue Mar 18 21:12:23 2008
  | Mapset:   spatialtech2008                Login of Creator: cmbarton
  | DataBase: /Users/Shared/grassdata
  | Title:    Resample by bilinear interpolation ( elev500bilinear )
  | Timestamp: none
  |   Type of Map:  raster               Number of Categories: 255
  |   Data Type:    DCELL
  |   Rows:         1350
  |   Columns:      1500
  |   Total Cells:  2025000
  |        Projection: Lambert Conformal Conic
  |            N:     228500    S:     215000   Res:    10
  |            E:     645000    W:     630000   Res:    10
  |   Range of data:    min = nan  max = nan
  |   Data Source:
  |    elev_pts500 at spatialtech2008
  |    Source map NS res: 10   EW res: 10
  |   Data Description:
  |    generated by r.resamp.interp
  |   Comments:
  |    r.resamp.interp input="elev_pts500 at spatialtech2008"
 output="elev500b\   |
  |    ilinear" method="bilinear"
 GRASS 6.3.svn (nc_spm_07):~ > r.info elev500nearest
  | Layer:    elev500nearest                 Date: Tue Mar 18 21:12:59 2008
  | Title:    Resample by nearest interpolation ( elev500nearest )
  | Timestamp: none
  |   Data Type:    DCELL
  |   Rows:         1350
  |   Columns:      1500
  |   Range of data:    min = 57.820839  max = 154.312943
  |   Data Source:
  |   Data Description:
  |   Comments:
 output="elev500n\   |
  |    earest" method="nearest"
 GRASS 6.3.svn (nc_spm_07):~ > r.univar elev500nearest
  100%
 total null and non-null cells: 2025000
 total null cells: 2024500
 Of the non-null cells:
 n: 500
 minimum: 57.8208
 maximum: 154.313
 range: 96.4921
 mean: 111.107
 mean of absolute values: 111.107
 standard deviation: 21.0507
 variance: 443.131
 variation coefficient: 18.9463 %
 sum: 55553.4484596252
Ticket URL: <http://trac.osgeo.org/grass/ticket/100#comment:2>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
