[GRASS-dev] r.watershed and swap memory
honegger honegger at gmail.com
Wed Mar 19 18:29:30 EDT 2008
just looking for a code that's able to process a 50'000x60'000 grid.
streamflow sounds verz promising, but as it's only availible as a binary
it's not really usable within linux (as you would need exactly the same
specs..)
r.watershed is rather slow and terraflow isn't an option because of the
inscalability of the basin size.
has anybody other options or experiences?
hamish_b wrote:
>> > note these r.terraflow options:
>> >     STREAM_DIR   Location of intermediate STREAMs
>> >                  default: /var/tmp
> Glynn:
>> This should be in lower case. AFAICT, we never use upper case in
>> option names.
> another task for GRASS 7....
> H
> ____________________________________________________________________________________
> Never miss a thing.  Make Yahoo your home page.
> http://www.yahoo.com/r/hs
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
View this message in context: http://www.nabble.com/r.watershed-and-swap-memory-tp16116939p16154475.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
