[GRASS-dev] Re: [GRASS GIS] #61: vdigit makefile uses hardwired compile and link flags
GRASS GIS trac at osgeo.org
Mon Mar 24 15:24:53 EDT 2008
  Reporter:  kyngchaos  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect     |      Status:  new
  Priority:  major      |   Milestone:  6.4.0
 Component:  Python     |     Version:  6.3.0 RCs
Resolution:             |    Keywords:
Comment (by kyngchaos):
 You could look at GDAL for an example of configuring and running
 distutils.  Also, the old python bindings in GDAL (ogpython, in the pymod
 dir) used a manual-compile method that could be of use.  But distutils is
 standard stuff for python, so we shouldn't be afraid to use it.
 If we don't use distutils, for whatever reason, we're stuck with trying to
 configure some form of PYTHON_LD, like in the GDAL ogpython.
Ticket URL: <http://trac.osgeo.org/grass/ticket/61#comment:10>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
