[GRASS-dev] g.mapsets, print only accessible mapsets
Martin Landa landa.martin at gmail.com
Mon Mar 24 18:14:02 EDT 2008
2008/3/24, Glynn Clements <glynn at gclements.plus.com>:
> I've committed the patch, but changed mapset_opt->required to NO.
thanks, small issue here -- the '-l' flag ignores gisdbase= and
location= parameters, it always prints list of mapsets for the
*current* location. The attached patch should fix it. If you have no
objections I will applied in trunk.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: text/x-diff
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080324/714cc81b/g_available_mapsets2-0001.bin
