[GRASS-dev] New GRASS icons
Michael Barton michael.barton at asu.edu
Tue Mar 25 10:20:33 EDT 2008
On Mar 25, 2008, at 5:19 AM, grass-dev-request at lists.osgeo.org wrote:
> Date: Mon, 24 Mar 2008 18:00:36 -0700 (PDT)
> From: Robert Szczepanek <grass at szczepanek.pl>
> Subject: Re: [GRASS-dev] New GRASS icons
> To: grass-dev at lists.osgeo.org
> Message-ID: <16266114.post at talk.nabble.com>
> Content-Type: text/plain; charset=us-ascii
Hi Robert,
General comments. These look really nice.
> New version of icons for actions and basic objects in high
> resolution is
> ready.
> Plus some new icons for map display window toolbar.
Eye is perfect. Hollow asterisk is hard to figure out.
IMHO, the pencil needs color to tell what it is.
I like what you've done with the action icons, especially the way
you've replaced the more common folder icon with a more abstract
ring. If this can be seen clearly enough when the action icons
(small) are added to the object icons, it's a big improvement over
the normal.
Layer seems very good and understandable to me, as does map display.
Abstract map icon OK. It doesn't jump out and say "map" to me. BUT I
DO understand the symbolism and it's easy to learn. So this may be
the best option for the underlying concept. I assume that you'll use
interior designs/color to differentiate between different map types.
Those should make this even clearer.
These are shaping up in an impressive way. The planning put into this
will make it easier for users to learn and use this complex program.
Thanks
Michael
> http://www.szczepanek.pl/icons.grass/index.php#4
> And one question.
> Why "Constrain map to region geometry" icon gets during display
> additional
> border at left side and top?
> Robert
> View this message in context: http://www.nabble.com/New-GRASS-icons-
> tp16054598p16266114.html
> Sent from the Grass - Dev mailing list archive at Nabble.com.
