[GRASS-dev] Re: [GRASS-user] modify feature's values interactively
Moritz Lennert mlennert at club.worldonline.be
Thu Mar 27 09:06:14 EDT 2008
On 27/03/08 11:04, Martin Landa wrote:
> Hi,
> 2008/3/27, Moritz Lennert <mlennert at club.worldonline.be>:
> [snip]
>>  However, I just can't get it to work:
>>  I have
>>  GRASS 6.3.svn (spearfish60):~ > v.db.connect -p roads
>>  Vector map <roads at PERMANENT> is connected by:
>>  layer <1> table <roads> in database
>>  </home/mlennert/GRASS/DATA/spearfish60/PERMANENT/dbf/> through driver
>>  <dbf> with key <cat>
>>  Querying in display mode works as expected:
>>  East: 596271.961722
>>  North: 4924483.851675
>>  Map: roads
>>  Mapset: PERMANENT
>>  Type: Line
>>  Line: 51
>>  Longueur: 1416.211362
>>  couche: 1
>>  catégorie: 3
>>  Driver: dbf
>>  Database: /home/mlennert/GRASS/DATA/spearfish60/PERMANENT/dbf/
>>  Table: roads
>>  Key column: cat
>>  cat : 3
>>  label : secondary highway, hard surface
>>  But when I try to query it in edit mode, I get:
>>  "No database record available"
> strange, I used for testing also 'roads' from spearfish60, seems to work.
Is there a way to activate a "debug" mode in wxgrass to log what happens
behind the screen ?
>>  Also: probably the button's properties should be changed so that you can
>>  click on it again directly to change from one mode to the other.
>>  Currently you have to click on another button and then back on the query
>>  button to change mode.
> You don't need to change a tool, double-click on 'query' should show menu again.
Nope, doesn't work for me...
Moritz
