[GRASS-dev] [GRASS GIS] #109: wxgrass - d.vect and d.vect.chart: changing default checkbox options in GUI results in KeyError
GRASS GIS trac at osgeo.org
Thu Mar 27 09:36:49 EDT 2008
results in KeyError
 Reporter:  mlennert                 |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                   |      Status:  new
 Priority:  major                    |   Milestone:  6.4.0
Component:  Python                   |     Version:  svn-trunk
 Keywords:  wxgrass d.vect KeyError  |
 The command line for d.vect displayed in properties window of a vector
 layer does not correspond to the options displayed by the GUI. E.g. add a
 new vector layer and chose a map (I'll use fields at user1 here). The command
 line shown at the bottom of the properties window shows d.vect
 map=fields at user1. This is fine as it means that for all other options, we
 use the default. For the type option, the default is
 "point,line,boundary,centroid,area,face" and this is what is shown in the
 GUI where all the check boxes are ticked. However, if I uncheck any of
 these boxes for the first time, I get the following type of KeyError:
   File "/home/mlennert/SRC/GRASS/grass_trunk/dist.i486-pc-linux-
 gnu/etc/wxpython/gui_modules/menuform.py", line 1252, in OnCheckBoxMulti
 del currentValues[ theValue ]
 KeyError
 u'point'
 OR
 KeyError
 u'shape'
 The same happens with the d.vect.chart type options.
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/109>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
