[GRASS-dev] Current state of wxPython GUI
Martin Landa landa.martin at gmail.com
Thu Mar 27 10:40:51 EDT 2008
2008/3/27, Martin Landa <landa.martin at gmail.com>:
>  >  4. When starting with an empty "Layer Manager": after adding the first
>  >  layer (vector in my case), the "Map Display" does not draw anything when
>  >  clicking on the "Display map" icon. I need to click on "Re-render map".
>  >  This seems counter-intuitive to me.
Martin:
> Just enable auto-rendering (right-most checkbox in the map display statusbar).
sorry, I didn't read carefully. "Display Map" should behave like
"Re-render map" when you add/remove/change map layer.
TODO
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
