[GRASS-dev] Re: [GRASS GIS] #105: r.in.xyz: zscale parameter addition patch
GRASS GIS trac at osgeo.org
Sat Mar 29 18:41:17 EDT 2008
  Reporter:  neteler      |       Owner:  hamish
      Type:  enhancement  |      Status:  assigned
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  svn-trunk
Resolution:               |    Keywords:
Comment (by hamish):
 Don't worry, I don't mean to revert the -i flag, but I did want to make
 clear my design philosophy. If the input file is that badly broken then a
 million WARNINGs should be disincentive enough to discourage lazy abuse of
 the flag.
 FWIW, to chop off the last row of a file, use head with a negative index:
   head -n -1 filename.txt | r.in.xyz in=- out=foo ...
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/105#comment:3>
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
