[GRASS-dev] Re: failure compiling GRASS svn trunk on Mac OS X 10.4.11
William Kyngesburye woklist at kyngchaos.com
Mon Mar 31 21:56:11 EDT 2008
On Mar 31, 2008, at 8:36 PM, Michael Barton wrote:
> cmb-MBP-2:~/grass_dev/grass_src cmbarton$ cd ./gui/wxpython/vdigit
> cmb-MBP-2:~/grass_dev/grass_src/gui/wxpython/vdigit cmbarton$ make
> cc -dynamiclib -compatibility_version 6.3 -current_version 6.3 -
> install_name /Applications/Grass/GRASS-6.3.app/Contents/MacOS/lib/
> libgrass6_wxvdigit.dylib -o OBJ.i686-apple-darwin8.11.1/
> _grass6_wxvdigit.dylib -L/Users/cmbarton/grass_dev/grass_src/
> dist.i686-apple-darwin8.11.1/lib      OBJ.i686-apple-darwin8.11.1/
> cats.o OBJ.i686-apple-darwin8.11.1/digit.o OBJ.i686-apple-
> darwin8.11.1/driver.o OBJ.i686-apple-darwin8.11.1/
> grass6_wxvdigit_wrap.o OBJ.i686-apple-darwin8.11.1/line.o OBJ.i686-
> apple-darwin8.11.1/select.o OBJ.i686-apple-darwin8.11.1/vertex.o -
> lgrass_vect -lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz      -
> lgrass_dbmiclient -lgrass_dbmibase -lgrass_gis -lgrass_datetime -
> lz      -lgrass_gis -lgrass_datetime -lz      -lgrass_dgl -
> lgrass_dig2 -lgrass_gis -lgrass_datetime -lz     -lgrass_rtree  -
> lgrass_gis -lgrass_datetime -lz     -lgrass_linkm -lgrass_rtree  -
> lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -
> lgrass_dbmibase -lgrass_gis -lgrass_datetime -lz      -lgrass_gis -
> lgrass_datetime -lz      -lgrass_dbmibase -lgrass_gis -
> lgrass_datetime -lz       -L/Library/Frameworks/GDAL.framework/
> Versions/1.5/unix/lib -lgdal -lgrass_gis -lgrass_datetime -lz     -L/
> Library/Frameworks/GDAL.framework/Versions/1.5/unix/lib -lgdal -
> lgrass_vedit -lgrass_gis -lgrass_datetime -lz     -lgrass_vect -
> lgrass_gis -lgrass_datetime -lz     -lgrass_linkm -lgrass_rtree  -L/
> usr/local/lib/wxPython-unicode-2.8.7.1/lib   -framework IOKit -
> framework Carbon -framework Cocoa -framework System -framework
> QuickTime  -lwx_macud-2.8  -L/Library/Frameworks/Python.framework/
> Versions/2.5/lib/python2.5/config -ldl -lpython2.5 -lgdi
> /usr/bin/libtool: can't locate file for: -lgdi
> /usr/bin/libtool: file: -lgdi is not an object file (not allowed in
> a library)
> make: *** [OBJ.i686-apple-darwin8.11.1/_grass6_wxvdigit.dylib] Error 1
vdigit needs work - on all platforms I think - but especially for OSX.
See these for info, though it may be hard to put that all together
right away.  I could post my vdigit makefile if you like.
http://trac.osgeo.org/grass/ticket/61
http://trac.osgeo.org/grass/ticket/58
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the
past isn't a fiction designed to account for the discrepancy between
my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
