[GRASS-dev] GRASS 7 raster coding best practices
Yann Chemin yann.chemin at gmail.com
Sun May 4 01:21:48 EDT 2008
2008/5/4 Hamish <hamish_b at yahoo.com>:
> Yann Chemin wrote:
>  > > I could not find it for parameters in float format (G_OPT_F_INPUT?)
>  lib/gis/parser.c already defines G_OPT_F_* for input and output files,
>  and field separators for those files. Don't use that for floating point
>  input values.
  OK, good, so not G_OPT_F_*.
>  > > for example...
> >        input = G_define_option(G_OPT_F(D?)_INPUT) ;
>  >        input->key        =_("parameter");
>  >        input->type       = TYPE_DOUBLE;
>  >        input->required   = YES;
>  >        input->gisprompt  =_("value, parameter");
>  >        input->description=_("Value of the parameter");
>  >        /*input->answer     =_("0.000");*/
>  the only thing I see there that is a candidate for reuse as part of a
>  default macro is input->type=TYPE_DOUBLE. The others are all module
>  option dependent, e.g. "input->key =_("parameter");" is vague enough to
>  be useless in practice.
>  input->gisprompt is wrong, have a look at the GRASS 5 programmers manual
>  for a nice write up about what that is for (maybe in the GRASS 6 one too,
>  I'm not sure)
   Do you have a link to this one please?
>  >        input->guisection = _("Required");
>  FWIW I consider this to be redundant noise. If it is wished that the
>  module GUI(s) group required options in the first tab then they should
>  extract that from the input->required field.
  Can you provide an example of filling in input->required, that would
be nice to add.
>  Hamish
>       ____________________________________________________________________________________
>  Be a better friend, newshound, and
>  know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
