[GRASS-dev] Are the recursive calls a problem in Grass?
Martin Wegmann wegmann at biozentrum.uni-wuerzburg.de
Tue May 6 15:07:14 EDT 2008
Hello Roberto,
On Dienstag, 6. Mai 2008 20:45:46 roberto caselli wrote:
> I always start my application from command line and the a GUI window
> opens so I can write the input and press the RUN button. But I don't
> see any kind of message error inside that window.
I don't have your module command currently hence an example with a common
command:
if you do e.g.
d.rast
the GUI will pop up, if you do
d.rast --help
you will see syntax
d.rast [-oix] map=string [catlist=cat[-cat][,cat[-cat],...]]
   [vallist=val[-val][,val[-val],...]] [bg=color] [--verbose] [--quiet]
the parts in brackets are optional hence you just have to to enter
d.rast map=your_raster
to plot the raster.
If you do the same with your command you will get an error message (or not).
You can change the message output with
g.gisenv set=debug=5 (not too sure about that)
hope this helps, cheers, Martin
> Roberto
> Roberto,
> please try it on command line. Maybe then the error becomes
> visible (GUI may catch it silently).
> Markus
> On Tue, May 6, 2008 at 1:59 PM, roberto caselli
> <roberto.caselli at yahoo.it> wrote:
> > Does anyone have an idea or an advice for this problem? GRASS doens't
>  give
> > me any kind of error message so I don't undestand where the bug is.
>  It just
> > stop the execution! I hope in your experience.
> > Regards,
> > Roberto
> > roberto caselli <roberto.caselli at yahoo.it> ha scritto:
> >  Hello everyone,
> > I have a question for you. I'm working on a module that uses a
>  recursive
> > call to flow water from a cell to its neighbours. I tested it with
>  some
> > sample raster map but I didn't see any kind of output on the screen.
>  I saw
> > GRASS started running (i saw the green dressed runner above on the
>  right)
> > and then it stopped with the RUN button available to be pushed again.
> > I tried to comment the recursive call and everything went well.  (I
>  saw the
> > partial results of the execution of my module on the screen).
> > So I think the problem is due to this recursive call and I'd like to
>  know if
> > there is a way to fix this problem.
> > Regards,
> > Roberto
> > ________________________________
> >  Tante idee per la salvaguardia del pianeta su
> >  Yahoo! for good.
> >  Yahoo! for good.
> >  grass-dev mailing list
> >  grass-dev at lists.osgeo.org
> >  http://lists.osgeo.org/mailman/listinfo/grass-dev
>  Yahoo! for good.
