[GRASS-dev] GRASS 7 development started
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue May 6 21:50:55 EDT 2008
On Mon, 5 May 2008, Glynn Clements wrote:
>> FWIW I prefer to put { on the same line as the if/for/while as it
>> tightens up the code vertically. But that is just my personal preference.
> Right; I tend to prefer quite a lot of whitespace, probably more than
> most people.
It seems only right to mention here that I also much prefer the opening
brace of a conditional block on a line by itself ;) As well as IMHO making
the code look less cluttered and neater, I find the extra space also helps
me to see quickly at a glance where the start and end of a conditional
block are.
>> As far as -cs, -saf, -sai, -saw for space after if,for,while etc. I
>> prefer not to have that, to me those statements are like f(x), ie one is
>> an argument for the other not a separate idea. In a similar way to how
>> "G_some_fn ();" looks bad; just because if/for/while happen to be inbuilt
>> fns doesn't matter.
> If/for/while/etc aren't functions; that's one of the main reasons I
> prefer a space in that case, to distinguish them from function calls.
> E.g. searching for "\>(" (end-of-word marker immediately followed by
> left parenthesis) finds function calls without also catching the test
> expression of an if/while/for/switch statement.
That's a nice idea - I thought it looked fine (space after if/for/while),
but hadn't thought through the reasoning.
Paul
