[GRASS-dev] Re: [GRASS GIS] #155: ps.map: the "M" highlight problem
GRASS GIS trac at osgeo.org
Wed May 7 00:32:13 EDT 2008
  Reporter:  perk     |       Owner:  hamish
      Type:  defect   |      Status:  assigned
  Priority:  minor    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-trunk
Resolution:           |    Keywords:  ps.map highlight text labels
Comment (by perk):
 Replying to [comment:5 glynn]:
 > Replying to [comment:4 perk]:
 > > > before applying the patch I would like to ask about possible side
 effects -- does the "currentlinejoin 1 setlinejoin stroke setlinejoin"
 part need to be swiched off after drawing the labels, or will it be self
 contained?
 > > This should be self-contained.  "currentlinejoin" puts the current
 line join style on the Postcript stack, "1 setlinejoin" sets the join
 style to rounded, "stroke" draws the current path (does not affect the
 stack), and the final "setlinejoin" uses the value put on the stack
 earlier to return the join style to the previous value.
 > The normal way to make temporary changes to the rendering state is with
 gsave/grestore, e.g.:
 > gsave 1 setlinejoin stroke grestore
 Works for me.  The patch is updated.
 Bill
Ticket URL: <http://trac.osgeo.org/grass/ticket/155#comment:6>
