[GRASS-dev] [GRASS GIS] #160: v.report WinGRASS incompatability issue
GRASS GIS trac at osgeo.org
Fri May 9 19:12:42 EDT 2008
 Reporter:  isaacullah               |       Owner:  grass-dev at lists.osgeo.org
     Type:  defect                   |      Status:  new
 Priority:  major                    |   Milestone:  6.4.0
Component:  default                  |     Version:  6.3.0
 Keywords:  v.report paste WinGRASS  |
 v.report currently will not function in WinGRASS. I have determined that
 this is because it utilizes the bash command "paste", which is not
 supported in the Msys shell (ie. there is no such program as paste.exe in
 the Mysys/bin directory). I cannot think of an appropriate replacement for
 the way "paste" is being used in the current script, but I'm sure that
 some workaround can be discovered.
Ticket URL: <http://trac.osgeo.org/grass/ticket/160>
