[GRASS-dev] build problems on Mac OS X 10.5.2.
Sun May 11 15:17:22 EDT 2008
Glynn Clements wrote:
> It's autoconf's AC_EXEEXT macro which is the problem. It attempts to
> determine the executable suffix automatically, with the following
> code:
> We should probably eliminate the use of that macro in favour of a
> simple "if cygwin or mingw then .exe else nothing" test. I don't know
> of any other supported platform where executables have a suffix.
I've committed this change to SVN.
