R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
Michael Barton michael.barton at asu.edu
Mon May 12 10:28:03 EDT 2008
Marco,
In most (all?) cases with my students, the problem locations were made by
picking an EPSG code. This routine uses g.proj to create the location. The
same issue may be affecting r.in.gdal I suppose.
Michael
On 5/12/08 1:03 AM, "marco.pasetti at alice.it" <marco.pasetti at alice.it> wrote:
> Hi Michael,
> I never had problems creating locations from EPSG codes. I suppose that it's
> another problem, probably related to GDAL.
> Now I check the questions by Glynn. I hope that we can fix it :-)
> Marco
> Da: grass-dev-bounces at lists.osgeo.org per conto di Michael Barton
> Inviato: sab 10/05/2008 7.30
> A: grass-dev at lists.osgeo.org
> Oggetto: Re: [GRASS-dev] WinGRASS: r.in.gdal projection issue
> Marco,
> I reported something similar a month or so back. Some of my students using
> WinGRASS would import an SRTM or other file--or they would make a location
> from an EPSG code. Then when they tried to reproject into another location,
> they'd get an error that there is no projection file.
> It seems most common (only?) with some latlon locations. UTM's seem OK. It
> is also somewhat erratic. I assume that it is either a g.proj error or a bad
> EPSG entry.
> Michael
> On 5/9/08 8:35 PM, "grass-dev-request at lists.osgeo.org"
> <grass-dev-request at lists.osgeo.org> wrote:
>> > Message: 1
>> > Date: Fri, 9 May 2008 18:38:01 +0200
>> > From: <marco.pasetti at alice.it>
>> > Subject: R: [GRASS-dev] WinGRASS: r.in.gdal projection issue
>> > To: <marco.pasetti at alice.it>, <grass-dev at lists.osgeo.org>
>> > Message-ID:
>> > <FA8A693893F4CE4283B4473C79FA47D505BB41CF at FBCMST06V02.fbc.local>
>> > Content-Type: text/plain; charset="iso-8859-1"
>> > Hi all,
>> > I also tried to launch GRASS with GISBase without spaces (such as
>> C:\GISBASE),
>> > with the demolocation, and placing the input file (Z_39_3.ASC) in a path
>> > without spaces too (C:\), but I got the same result.
>> > Marco
>> > PS: VMware seems to not be a good solution, it requires a too performant
>> > hardware; I'll go back with the linux dual boot solution.
>> > ________________________________
>> > Da: grass-dev-bounces at lists.osgeo.org per conto di marco.pasetti at alice.it
>> > Inviato: ven 09/05/2008 16.51
>> > Oggetto: [GRASS-dev] WinGRASS: r.in.gdal projection issue
>> > Hi all,
>> > During WinGRASS 6.3.0 testings I encontered a problem with the r.in.gdal
>> > module: it reports no errors, and correctly import rasters, but fails
>> creating
>> > the projection for the new location created during raster import.
>> > I explain better with an example: I imported an SRTM tile, to be imported
>> in a
>> > new location named "test", with the following command line:
>> > r.in.gdal {input=C:/Documents and Settings/Marco/Documenti/GIS Data
>> > Repository/SRTM v3.0 DEM 90m/Z_39_3.ASC} output=Z_39_3.dem location=test
>> > At the end of the Run it reports as follows in the output window:
>> > Location <test> created
>> > r.in.gdal complete.
>> > After that I exit GRASS and I restart it accessing the location test: the
>> > raster have been correctly imported, the region set to the raster
>> boundaries,
>> > but if type:
>> > g.proj -j
>> > it reports
>> > XY (unprojected)
>> > talking in IRC with a linux huy, I asked him to do the same command using
>> the
>> > same raster with GRASS-6.3.0SVN: the location test, for him, has a correct
>> > projection (that is latlong wgs84 and so on...). So I guess that is a
>> windows
>> > problem, but I don't really know why since the command doesn't report
>> errors!
>> > any suggestions?
>> > This said I have another question for you: I have linux (ubuntu) installed
>> on
>> > my system with xual boot along with xp pro sp2, but it's really impossible
>> to
>> > me to always reboot within the two systems to make tests, so today I
>> decided
>> > to install VMware with an ubuntu (8.04) virtual machine. I would use this
>> VM
>> > to make tests on GRASS and directly check if WinGRASS problems are strictly
>> > referred to windows platform or to other problems. Now I have a doubt:
>> > 1. Install GRASS from a destributed package or
>> > 2. Manually compile and install all the needed dependencies (if not already
>> > intalled, obviously) with the same support configuration as I did for the
>> > current WinGRASS release, in order to check if WinGRASS errors are
>> generated
>> > by dependency issues and not by platform problems?
>> > Thanks for your help,
>> > Regards
>> > Marco
>> > -------------- next part --------------
>> > An HTML attachment was scrubbed...
>> > URL:
http://lists.osgeo.org/pipermail/grass-dev/attachments/20080509/1255b67d/attac
>> > hment-0001.html
> __________________________________________
> Michael Barton, Professor of Anthropology
> Director of Graduate Studies
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
> phone: 480-965-6213
> fax: 480-965-7671
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20080512/121b4541/attachment-0001.html
