[GRASS-dev] Trouble while compiling with BLAS and LAPACK
Thomas Becker thomasgeo at gmx.de
Wed May 14 07:30:46 EDT 2008
Hi Listers,
   I am running in problems while compiling GRASS 6.3 with BLAS and
LAPACK support. The ./configure is done by:
CFLAGS="-g -Wall" ./configure --with-blas --with-lapack
--with-gdal=/usr/bin/gdal-config --with-tcltk=/usr/include/tcl8.4/
   So far everything is fine.
   Running make stops with Error 1 and the error.log reveals quite some
problems. The first problem is pointing to lapack.h and is comming from
gmath. Lapack was installed from the repositories of Ubuntu as well as Blas.
   Can someone confirm these problems and/or maybe has a way out of it?
Cheers Thomas
