[GRASS-dev] Make/Configure Issue using Eclipse/Windows
peter.loewe at gmx.de peter.loewe at gmx.de
Wed May 14 10:40:50 EDT 2008
I am trying to get GRASS compiled in a Eclipse/CDT environment on a Windows machine.
The approach includes wrapping the "configure / make /make install" -process in an ant file and works very well behaved on linux boxes.
On a windows box (using msys) "something" is going wrong regarding the header files. This is the first error produced by make, the follow-up errors are similar:
     [exec] gcc -I/d/Nutzer/ploewe/workspace/neo63/dist.i686-pc-mingw32/include -IC:\msys\1.0\local\include -g -O2  -IC:\msys\1.0\local\include     -DPACKAGE=\""grasslibs"\" -D_FILE_OFFSET_BITS=64   -DPACKAGE=\""grasslibs"\"  -I/d/Nutzer/ploewe/workspace/neo63/dist.i686-pc-mingw32/include -o OBJ.i686-pc-mingw32/auto_mask.o -c auto_mask.c
     [exec] In file included from auto_mask.c:17:
     [exec] G.h:2:23: rpc/types.h: No such file or directory
     [exec] G.h:3:21: rpc/xdr.h: No such file or directory
     [exec] G.h:42: error: syntax error before "XDR"
     [exec] G.h:42: warning: no semicolon at end of struct or union
     [exec] G.h:47: error: syntax error before '}' token
     [exec] make[3]: *** [OBJ.i686-pc-mingw32/auto_mask.o] Error 1
The GRASS sources have been downloaded from the SVN, so all files are available.
Suggestions, anyone ?
Cheers,
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
249 Spiele für nur 1 Preis. Die GMX Spieleflatrate schon ab 9,90 Euro.
Neu: Asterix bei den Olympischen Spielen: http://flat.games.gmx.de
