[GRASS-dev] [GRASS GIS] #169: Request for r.edit
GRASS GIS trac at osgeo.org
Thu May 15 22:51:08 EDT 2008
 Reporter:  cmbarton     |       Owner:  grass-dev at lists.osgeo.org
     Type:  enhancement  |      Status:  new
 Priority:  major        |   Milestone:  6.4.0
Component:  default      |     Version:  svn-develbranch6
 Keywords:               |
 I'd like to request a module with a suggested name of r.edit. This would
 let you specify an existing map to edit, and then specify the xy
 coordinages, cat, and optionally label of a cell to change. Preferably,
 the input parameter would accept a list of
 x y cat [label],x y cat [label],x y cat [label],...
 so that multiple cells could be changed. I realize that you can accomplish
 this with r.in.poly and r.patch and have even made a script to do it.
 However, it is a clunky work around, slower than directly changing values,
 seems to have some difficulties in maintaining labels for fp maps. This
 could be used to create a nicer raster digitizer and can be used by ABM's
 and other modeling scripts developed in Python and other OO languages.
Ticket URL: <http://trac.osgeo.org/grass/ticket/169>
