[GRASS-dev] Re: [GRASS GIS] #171: d.vect: -c type=area doesn't draw boundary
GRASS GIS trac at osgeo.org
Fri May 16 11:44:31 EDT 2008
  Reporter:  hamish   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect   |      Status:  new
  Priority:  major    |   Milestone:  6.4.0
 Component:  default  |     Version:  svn-develbranch6
Resolution:           |    Keywords:  d.vect
Comment (by hamish):
 correction: it draws the boundaries, but uses the same color as the fill
 when it should make the area color random and the line color respect
 color=. e.g.:
  d.vect -c type=area fcolor=none
 see the d.vect symbol drawing code for an example of using a primary and
 secondary color in place of line= and fill=.
 Hamish
Ticket URL: <http://trac.osgeo.org/grass/ticket/171#comment:1>
