[GRASS-dev] G_OPT_* constants
Markus Neteler
neteler at osgeo.org
Sat May 24 13:58:09 EDT 2008
On Sat, May 24, 2008 at 11:10 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> GRASS GIS wrote:
>> IMPORTANT to all SVN users:
>> After the recent change in parser.c you need to RECOMPILE GRASS from
>> scratch.
>> I wanted to post this but forgot about it. So
>> make distclean
>> sh configure ...
>> make
> Might it be better to just assign explicit values to the G_OPT_*
> constants, so that this issue doesn't occur whenever new constants are
> added or removed?
> A related, but distinct option is to make e.g. G_gisinit() check that
> the library and module were compiled with the same version of gis.h,
> I.e.:
> include/gis.h:
> int G__gisinit(const char *, const char *);
> #define GIS_H_VERSION "$Revision$"
> #define G_gisint(pgm) G__gisinit(GIS_H_VERSION, (pgm))
> lib/gis/gisinit.c:
> int G__gisinit(const char *version, const char *pgm)
> if (strcmp(version, GIS_H_VERSION) != 0)
> G_fatal_error(_("Incompatible library version for module"));
Sounds like a very good suggestion to me. I got trapped by this
myself a couple of times in the past.
Markus
