[GRASS-dev] georeferencer - inspiration from gvSIG ?
Markus Neteler neteler at osgeo.org
Sat May 24 16:02:30 EDT 2008
On Sat, May 24, 2008 at 4:46 AM, Hamish <hamish_b at yahoo.com> wrote:
> I would be nice to have the "auto" and "3d" i.points updated+moved from grass5 incoming / contrib code into
> grass6 addons, or at least well summarized for grass5 on a wiki page or so. the idea is to have a full plate of
> good ideas with demonstration code available while building the new wxGUI georeferencing app, thus a
> stronger roadmap of where we want it to go and what features to include.
Hamish,
which code do you mean? We have there grassaddons/imagery/i.points.auto.
The draft imagery roadmap is (see TODO file in main - should go into the Wiki):
TODO Image libraries:
  A)
    - lib/imagery/: standard lib, in use (i.* except for i.points3, i.rectify3)
    - imagery/i.ortho.photo/libes/: standard lib, in use
(i.ortho.photo, photo.*)
  B)
    - lib/image3/: never finished improvement which integrated the
standard lib and
                   the ortho lib. Seems to provide also ortho rectification for
                   satellite data (i.points3, i.rectify3)
TODO Image modules:
    - merge of i.points, i.vpoints, i.points3
    - merge of i.rectify and i.rectify3
    - addition of new resampling algorithms such as bilinear, cubic convolution
      (take from r.proj?)
    - add other warping methods (maybe thin splines from GDAL?)
    - implement/finish linewise ortho-rectification of satellite data
    - Add support for > 8bit colors (only 0-255 supported currently)
Markus
