[GRASS-dev] Re: [GRASS GIS] #177: wxpython gui for v.in.dxf defaults to overwrite
GRASS GIS trac at osgeo.org
Sun May 25 08:22:44 EDT 2008
  Reporter:  brian   |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect  |      Status:  new
  Priority:  minor   |   Milestone:  6.4.0
 Component:  Python  |     Version:  svn-trunk
Resolution:          |    Keywords:  wxpython
Comment (by martinl):
 Replying to [comment:5 brian]:
 > There is a slight change in behaviour of this bug. The --overwrite does
 not appear until after selecting the input dxf file.
 I guess the fixed bug is unrelated. You can enable/disable default value
 for 'overwrite' in
 Config->Preferences->Command->Allow output files to overwrite existing
 files
 When you launch GUI dialog for v.in.dxf you need to enter required
 parameters ('Enter parameter for v.in.dxf' in dialog statusbar). You get
 v.in.dxf --overwrite input=/home/martin/src/grass6_devel/x4.dxf
 disabling/enabling 'Allow output files to overwrite existing files' in
 'Optional' tab removes/adds '--overwrite' flag to the command.
 Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/177#comment:6>
