[GRASS-dev] proper v.parallel behavior on strange input
Росен Матев r.matev at gmail.com
Mon May 26 08:02:17 EDT 2008
Hello,
I'm currently reimplementing v.parallel/v.buffer. There are some
strange inputs with no apparent behavior. Please suggest what should
v.parallel do on such inputs.
I've attached a simple input. Try to make a parallel line on right
side of the given line; distance is greater than 5m (let's say 7m).
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20080526/3eadb9e2/issue.png
