[GRASS-dev] GRASS 7 development started
Hamish hamish_b at yahoo.com
Fri May 30 22:28:58 EDT 2008
Hamish:
> > better example:
> >  G_fatal_error
> > 	(_
> > 	 ("Can't get projection info of current location
Glynn:
> Can you identify a particular file where this happens, so
> that I can try things?
> I didn't realise that it would insert a line break
> between a function name and its argument list.
the above example is from raster/r.sun/main.c
Hamish
