[GRASS-dev] wrong configure documentation for compilation with wxwidgets ?
Moritz Lennert mlennert at club.worldonline.be
Wed Nov 5 08:52:19 EST 2008
On 05/11/08 14:41, Martin Landa wrote:
> Hi,
> 2008/11/5 Moritz Lennert <mlennert at club.worldonline.be>:
>> Below discussion comes from the DebianGIS mailing list. It raises an issue
>> about documentation of the configure options.
>> ./configure --help shows:
>> --with-wxwidgets[=path/wx-config] enable wxWidgets support (wx-config with
>> path, e.g. '--with-wxwidgets=/usr/local/bin/wx-config', default: no)
>> but this does not seem to work, while below solution does. Looking through
>> the configure file, I don't really understand why this is so (but then
>> again, I can't claim that I understand everything in that file).
>> So, is the documentation wrong, or does below solution just work by chance ?
>> On Tue, 04 Nov 2008 17:16:26 +0100,
>> Moritz Lennert <mlennert at club.worldonline.be> wrote:
>>> On 05/11/08 03:13, Seb wrote:
>>>> Yes, I liked that better too.  However, modifying that target as:
>>>> ,-----[ rules (lines: 66 - 67) ]
>>>> --with-wxwidgets=/usr/lib/wx/config/gtk2-unicode-release-2.8 \
>>> It should be:
>>> --with-wx=/usr/lib/wx/config/gtk2-unicode-release-2.8\
>>> --with-wxwidgets \
>> Yes, this worked.  The packages built fine.  The only problem reamining
>> is the clash betwee grass-preview-doc and grass-doc I posted earlier.
>> Thanks everyone for your help.
> there is no --with-wx just --with-wxwidgets which takes as argument
> *path to wx-config* (similary e.g. to --with-gdal)
But what is weird is that the above combination works, whereas giving
the path to wx-widgets doesn't...
> still resulted in this at build time:
> ---<---------------cut here---------------start-------------->---
> checking whether to use wxWidgets... yes
> checking for wx-config... /usr/bin/wx-config
> checking wxWidgets version... 2.6.3
> configure: error: *** wxWidgets 2.8.1 or later is required.
> make: *** [config-stamp] Error 1
> debuild: fatal error at line 1301:
> couldn't exec fakeroot debian/rules:
> ---<---------------cut here---------------end---------------->---
And both for him and for me it works with with-wx.
Moritz
IIUC, configure looks for the string wx-config in the path given to
wxwidgets, but as you can see in Debian (when you have several version
of wxwidgets installed) you the file might not be called *wx-config*.
