[GRASS-dev] r.mapcal and python
Massimiliano Cannata massimiliano.cannata at supsi.ch
Tue Nov 11 07:57:24 EST 2008
Glynn Clements wrote:
> Roberto Antolí­n wrote:
>>> Ciao Roberto,
>>> try with this solution:
>>> output='yourmap'
>>> map1='yourmap1'
>>> map2='yourmap2'
>>> cmdargs2=["%s=if(%s>%s,10000,0)"%(output,map1,map2)]
>>> os.spawnvp(os.P_WAIT,"r.mapcalc", ["r.mapcalc"] + cmdargs2)
>> Thank you, Maxi! It works perfectly well. I think I'll use this solution
>> rather than the grass.py library for 'r.mapcalc'.
> Don't use the os.spawn* functions; they have been superseded by
> subprocess.Popen() and subprocess.call().
Yes, replace spawn* with popen or call. It is the right direction.
P.s.: Only call can handle the P_WAIT mode?
Maxi
Dr. Massimiliano Cannata
Environmental & Geomatic Engineer
Institute of Earth Sciences - SUPSI
Trevano, C.P. 72, CH-6952 Canobbio, SWITZERLAND
Tel:    +41 (0)58 / 666 62 14
Fax:    +41 (0)58 / 666 62 09
E-mail: massimiliano.cannata at supsi.ch
Web:
http://www.ist.supsi.ch
http://istgis.ist.supsi.ch:8001/geomatica/
