[GRASS-dev] r34409: Replace r.buffer with a script using r.grow.distance
Hamish hamish_b at yahoo.com
Fri Nov 21 06:36:33 EST 2008
re. r34409: Replace r.buffer with a script using r.grow.distance
I am wondering, does r.grow.distance do the right thing in Lat/Lon?
If not, then the C version of r.buffer still has an important advantage
and should stay.
e.g.: (latest SVN for r.in.poly; see attached)
g.region n=60S s=85S w=30 e=60 res=0:05
r.in.poly in=- out=dot_map << EOF
P
 45E 72:30S
= 1 dot
EOF
g.region n=43:20S s=90S w=10 e=80E
r.buffer in=dot_map out=dot_map.500nm dist=500 units=nautmiles
d.mon x0
d.rast dot_map.500nm
d.grid 30
Hamish
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20081122/47893a5d/rbuffer_C.png
