[GRASS-dev] Re: [GRASS-SVN] r34608 - grass/branches/develbranch_6/vector/v.in.ascii
Martin Landa landa.martin at gmail.com
Sat Nov 29 04:20:06 EST 2008
well, this fix doesn't solve problem in wxGUI (range of SpinCtrl). I
think it should be fixed in gislib level.
Martin
2008/11/29  <svn_grass at osgeo.org>:
> Author: hamish
> Date: 2008-11-28 19:34:25 -0500 (Fri, 28 Nov 2008)
> New Revision: 34608
> Modified:
>   grass/branches/develbranch_6/vector/v.in.ascii/in.c
> Log:
> Column numbers must not be negative (trac #278)
> Modified: grass/branches/develbranch_6/vector/v.in.ascii/in.c
> --- grass/branches/develbranch_6/vector/v.in.ascii/in.c 2008-11-28 23:04:15 UTC (rev 34607)
> +++ grass/branches/develbranch_6/vector/v.in.ascii/in.c 2008-11-29 00:34:25 UTC (rev 34608)
> @@ -193,6 +193,9 @@
>     catcol = atoi(catcol_opt->answer) - 1;
> +    if (xcol+1 < 1 || ycol+1 < 1 || zcol+1 < 0 || catcol+1 < 0)
> +       G_fatal_error(_("Column numbers must not be negative"));
>     if (old->answer != NULL) {
>        if ((ascii = fopen(old->answer, "r")) == NULL) {
>            G_fatal_error(_("Unable to open ASCII file <%s>"), old->answer);
> grass-commit mailing list
> grass-commit at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
