[GRASS-dev] Re: [GRASS GIS] #385: description for v.db.reconnect.all
GRASS GIS trac at osgeo.org
Sat Nov 29 15:16:56 EST 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:1 nikos]:
 > Question: where should the "change" added? Not in the "tmp.html" file.
 But then, in the description.html? Where?
 Add a "notes" section at the end of description.html.
 The "parameters" section is generated by running the script with the
 --html-description option. The text is taken from the corresponding "#%
 description:" line at the top of the script.
 I note that the script already has that text; it should be removed. For
 option descriptions, brevity is more important than exhaustively
 documenting the option's semantics.
Ticket URL: <http://trac.osgeo.org/grass/ticket/385#comment:2>
