[GRASS-dev] starting GIPE modules insertion in main svn
Yann Chemin yann.chemin at gmail.com
Wed Oct 1 03:31:56 EDT 2008
Hi Glynn,
2008/10/1 Glynn Clements <glynn at gclements.plus.com>:
> Yann Chemin wrote:
>> > Right; you need <unistd.h> for swab().
see below about this
>> are there forgiving compilers around, so that this was not required explicitely?
> By default, "implicit declaration of function ..." only generates a
> warning, not an error. However, the resulting binary is likely to
> crash if the compiler guesses the function's prototype incorrectly.
> IIRC, Markus normally compiles with
> -Werror-implicit-function-declaration, which will cause implicit
> function definitions to generate an error.
I have made that my default compile option now.
>> > Also, the fact that the swab() calls are there seems to imply that the
>> > data was imported incorrectly in the first place. If any byte swapping
>> > needs to be done, it should normally be done when the data is
>> > imported.
>> My mastering of binary reading is weak, so I guess you make sense,
>> but technically I would feel weak to modify it. For what I undestand
>> it was initially meant (outside of GRASS) to isolate a small number
>> of bits for & comparison.
> In that case, I'm guessing that the code was designed for a specific
> architecture, one whose byte order is opposite to that used by the
> data.
> Ultimately, if you don't understand the format, or how the code is
> supposed to work, it's probably better not to commit it.
I agree.
Let me try to remove swab(). It should help clarify things.
Thanks for all,
Yann
Yann Chemin
International Rice Research Institute
Office: http://www.irri.org/gis
Perso: http://www.freewebs.com/ychemin
YiKingDo: http://yikingdo.unblog.fr/
