[GRASS-dev] Re: vdigit working on Mac mostly
Martin Landa landa.martin at gmail.com
Thu Oct 9 04:04:58 EDT 2008
2008/10/9 Michael Barton <michael.barton at asu.edu>:
>> no, the combobox in vdigit toolbar hasn't been removed. Seems to be a
>> bug in Mac wxPython. Can you see combobox in map toolbar?
> I went ahead and applied the Mac fix for the missing combo box to
> develbranch_6. Could you check to see if it works OK for you? Thanks.
Seems to work here (backpored to trunk).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
