[GRASS-dev] Re: [GRASS GIS] #324: Ability to handle subgroups with general commands as all other datatypes
GRASS GIS trac at osgeo.org
Thu Oct 9 20:04:18 EDT 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  major        |   Milestone:  6.4.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:  subgroup, general commands
  Platform:  All          |         Cpu:  Unspecified
Comment (by nikos):
 Glynn, thank you for the explanation. Perhaps adding such functions in
 i.group would make sense (?)
 example: i.group group=pca -s # -s: list subgroups and not individual maps
 added in the group
 I'll try to make my point: I have lots of principal components that came
 from different band combinations, why should I need to create as much
 groups as the combinations from which they came from (in order to have an
 easy overview for later classification tasks for example).
 I only have one group called pca and in it lots of subgroups depending on
 the initial band combination used to produce these components. Then I can
 apply a classification using the same training set upon the different
 subgroups. It takes less effort to "invent" names for groups/subgroups and
 gives me the feel that its easier to review/check the data
 (=groups/subgroups).
 This is how I thought/think that subgroups are meaningful. Would you
 recomment another "best practice" of GRASS groups/subgroups handling?
Ticket URL: <http://trac.osgeo.org/grass/ticket/324#comment:3>
