[GRASS-dev] default for r.walk
Helena Mitasova hmitaso at unity.ncsu.edu
Fri Oct 10 14:32:49 EDT 2008
I opened the code and it has it right in header:
TOTAL COST = [(WALKING ENERGY ) + (LAMBDA*FRICTION)]
maybe this is how it should go into the man page
Helena
On Oct 10, 2008, at 2:21 PM, Michael Barton wrote:
> I've been emailing with Helena to try to understand exactly how
> lambda and a friction surface interacts with information about
> topography (extracted from a DEM) in r.walk. It seems a good idea to
> put this back on the list. Perhaps I'm the only one a little in the
> dark, but maybe it can help others.
> On Oct 10, 2008, at 10:40 AM, Helena Mitasova wrote:
>>> To clarify for me, is it
>>> total cost = (movement time cost + lambda) * friction costs
>>> OR
>>> total cost = movement time cost + (lambda * friction costs)
>> I did not look into the code but if there are no brackets in the
>> code, this second interpretation applies.
> For anyone familiar with the code, is this the case? If so, should I
> be thinking in time units for creating a friction map? If I
> remember, r.walk normally outputs in seconds to traverse the cell.
> So, should the friction map be in additional seconds to traverse the
> cell? Or is friction a weighting factor (i.e., multiplicative rather
> than additive)?
> Thanks
> Michael
