[GRASS-dev] how to find out current working db driver and database?
Sat Oct 11 23:28:59 EDT 2008
Michael Barton wrote:
> As a start to fixing the currently broken table and column select
> combo boxes in the wxPython GUI, is there some way to find out what
> the current working setting is for the database driver and database
> (i.e., path)?
The defaults can be obtained with "db.connect -p", while the
parameters used by a specific vector map can be obtained with
"v.db.connect -g".
lib/python/grass.py has interfaces to both of these:
	def db_connection():
	    """Return the current database connection parameters
	    (interface to `db.connect -p').
returns a dictionary:
    kv = grass.db_connection()
    database = kv['database']
    driver = kv['driver']
while:
	def vector_db(map, layer = None, **args):
	    """Return the database connection details for a vector map
	    (interface to `v.db.connect -g').
returns either a list:
    f = grass.vector_db(map, layer)
    if not f:
	grass.fatal("An error occured while running v.db.connect")
    layr = f[0]
    table = f[1]
    keycol = f[2]
    database = f[3]
    driver = f[4]
or a list of such lists if the "layer" argument is omitted.
Note: if you intend to parse the output from "v.db.connect -g"
yourself, use the (recently-added) fs= option. The default field
separator is a space, but the database may be a pathname, which might
contain spaces, particularly on Windows.
