[GRASS-dev] Re: [GRASS GIS] #332: Uniform order for "at=" screen coordinates in d.* modules
GRASS GIS trac at osgeo.org
Mon Oct 13 02:04:13 EDT 2008
  Reporter:  nikos        |       Owner:  grass-dev at lists.osgeo.org
      Type:  enhancement  |      Status:  new
  Priority:  minor        |   Milestone:  7.0.0
 Component:  default      |     Version:  unspecified
Resolution:               |    Keywords:
  Platform:  Unspecified  |         Cpu:  Unspecified
Comment (by glynn):
 Replying to [comment:1 hamish]:
 > see comments in grass64.svn/lib/display/cnversions.c if you want
 > to look deeper.
 Note: that file has changed a great deal in 7.0 (and may well change
 further), so don't pay too much attention to anything contained in it.
 In 7.0, the "U" coordinates aren't required to be cartographic
 coordinates, e.g. d.graph uses percentages (i.e. coordinates range from
 0,0 to 100,100). Also, physical coordinates (pixels, points) are hardly
 used now by d.* commands. The only remaining vestige is that the
 conversion factor is often used for sizing text and certain other elements
 (e.g. symbols).
Ticket URL: <http://trac.osgeo.org/grass/ticket/332#comment:2>
