[GRASS-dev] convergence angle
Markus Neteler neteler at osgeo.org
Tue Oct 21 14:27:04 EDT 2008
On Tue, Oct 21, 2008 at 1:38 PM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> I've applied this in 7.0:
>        --- include/gprojects.h (revision 33947)
>        +++ include/gprojects.h (working copy)
>        @@ -32,7 +32,7 @@
>         struct pj_info
>        -    projPJ *pj;
>        +    projPJ pj;
>             double meters;
>             int zone;
>             char proj[100];
> It doesn't result in a warning in GRASS because PROJECTS_H isn't
> defined, so the void* version is used, and implicit casts to/from
> void* never generate a warning.
Backported to 6.4.svn.
Markus
