[GRASS-dev] Re: [GRASS-stats] Re: [R-sig-Geo] writing shapefiles / DBF files when input data contains NA
Dylan Beaudette dylan.beaudette at gmail.com
Wed Oct 29 10:08:23 EDT 2008
On Wed, Oct 29, 2008 at 3:00 AM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Oct 14, 2008 at 11:13 AM, Markus Neteler <neteler at osgeo.org> wrote:
>> On Tue, Oct 14, 2008 at 8:59 AM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
>>> On Mon, 13 Oct 2008, Dylan Beaudette wrote:
>>>> Have the changes in the rgdal package made it into the mainstream code? I
>>>> have submitted tickets to the GRASS trac site for the v.out.ogr patch. The
>>>> changes you suggested appear to work well.
>>> No sign of any change in the 6.3 or 6.4 trunks, unfortunately. 7.0 has the
>>> same bug. No response to the posting or your tickets. The only relevant
>>> thread was Markus' suggesting a name change in 7.0. Hamish: could you please
>>> prod the person(s) needed to move on ticket 333, and get them to do the same
>>> on 6.4 and 7.0 (the patch is for 6.3)?
>> I have fixed trax #333 now with minor modification (C++ style comments
>> are no good).
>> Applied to 6.3.svn, 6.4.svn, 7.svn.
> Sorry, discovered only now that the 6.4.svn fix was uncommitted on my
> laptop. Submitted as revision 34049, unfortunately with wrong ticket
> reference.
> So, now this issue should be really solved.
> Markus
Thanks Markus. I'll update my local copy and give it a try.
This should fix several long-standing issues with moving data from GRASS->R.
Cheers,
Dylan
