[GRASS-dev] r.uselr
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Oct 29 21:00:19 EDT 2008
Yann,
when you have some time, could you please add units to the
description / help for r.usler
(are whichever other modules needs it), something like what we have
added for simwe.
I assume the rainfall input is in [mm] but it would be good to
provide this info, as well as
the units for output.
thank you,
Helena
On Oct 29, 2008, at 5:15 PM, Helena Mitasova wrote:
> I have commented out the sites-related input/output from simwe in
> trunk.
> It compiles and runs with grass7 updated today - I tested it with
> the examples
> from grassbook and some variations of the parameters.
> Are these changes enough to get it back into grass7?
> (there is still the issue of 3 separate waterglobs.h - I need to
> talk to Jaro
> to see what would be the best way to fix it).
> Also, should I submit these changes to GRASS64 so that it runs in
> winGRASS?
> (I am not sure what was the problem there)
> Helena
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
