[GRASS-dev] Re: [GRASS GIS] #287: vdigit: don't force 'cat' as the key column name
GRASS GIS trac at osgeo.org
Sat Sep 6 06:03:46 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  minor     |   Milestone:  6.4.0
 Component:  default   |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by martinl):
 Replying to [comment:2 msieczka]:
 > Cool, but that's not the same thing. I mean, that, ideally, the key
 column setting should be adjustable ad command run time, too (this issue
 is not limited to vdigit actually).
 Not only vdigit, also creating vector map layer from main menu
 ('Vector->Develop vector map->Create new vector map').
 Do you mean to use GIS/environment variable like GRASS_KEY_COLUMN ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/287#comment:3>
