[GRASS-dev] Re: [GRASS GIS] #291: font settings not saved
GRASS GIS trac at osgeo.org
Sat Sep 6 13:16:40 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [ticket:291 msieczka]:
 > Also, I don't how to change encoding in Preferences > Display > Set
 font. Anything I enter instead of the default "ISO-8859-1" is discarded
 next time I enter the dialog.
 The font encoding needs to be set to whatever Python uses when passing
 strings to the OS. This will probably be the locale's encoding unless it
 explicitly uses something else. Also, the encoding only affects FreeType
 fonts; stroke fonts are essentially ASCII.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:2>
