[GRASS-dev] Re: [GRASS GIS] #293: wxGUI should provide a switch for region-constrained/free display mode
GRASS GIS trac at osgeo.org
Sat Sep 6 16:18:37 EDT 2008
  Reporter:  msieczka  |       Owner:  grass-dev at lists.osgeo.org
      Type:  defect    |      Status:  new
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by mlennert):
 On 06/09/08 19:51, Michael Barton wrote:
 > On Sep 6, 2008, at 4:03 AM, <grass-dev-request at lists.osgeo.org>
 > wrote:
 >> Message: 8 Date: Sat, 06 Sep 2008 10:53:32 -0000 From: "GRASS GIS"
 >> <trac at osgeo.org> Subject: [GRASS-dev] [GRASS GIS] #293: wxGUI
 >> To: undisclosed-recipients:; Message-ID:
 >> <042.c32e73800c23ec17093f4df5c04885a3 at osgeo.org> Content-Type:
 >> text/plain; charset="utf-8"
 >> display mode
 >> Type:  defect    |      Status:  new Priority:  major     |
 >> Milestone:  6.4.0 Component:  wxGUI     |     Version:
 >> svn-develbranch6 Keywords:            |    Platform:  All Cpu:  All
 >> wxGUI should provide an easily accessible switch for region-
 >> constrained/free display mode. Like gis.m does.
 IIUC, this is linked to (a duplicate of ?) #106.
 > This is a feature request, not a defect. This kind of setting tries
 > to have the image proportions inside the display window conform to
 > the computational region proportions, rather than match the display
 > window proportions.
 > Can you or others give some examples of actual display use that
 > requires this kind of option (warranting the added complexity in
 > display rendering that it involves) that cannot be achieved in
 > another way?
 In gis.m this mode does not necessarily conform to computational region
 proportions, but conforms to the proportions you indicate with your
 zoom. It can also be used to show the exact region proportions,
 something which I find extremely useful.
 Now, maybe the fact that in the wx gui you can show the extent of the
 computational region solves this issue (although it doesn't solve the
 resolution issue raised in #106), I'll just have to work with it a bit
 more to really find out, but up to now I have found the absence of the
 constraint mode a nuisance...
 Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/293#comment:1>
