[GRASS-dev] Re: [GRASS GIS] #291: font settings not saved
GRASS GIS trac at osgeo.org
Sun Sep 7 16:38:24 EDT 2008
  Reporter:  msieczka  |       Owner:  martinl
      Type:  defect    |      Status:  assigned
  Priority:  major     |   Milestone:  6.4.0
 Component:  wxGUI     |     Version:  svn-develbranch6
Resolution:            |    Keywords:
  Platform:  All       |         Cpu:  All
Comment (by glynn):
 Replying to [comment:3 msieczka]:
 > On my system encoding is pl_PL.UTF-8.
 "pl_PL.UTF-8" is the locale; the encoding is just "UTF-8".
 > Should I set the encoding in Preferences > Display > Set font be set to
 that, instead of ISO-8859-1?
 Probably. Try using some non-ASCII characters in e.g. d.text text="..."
 and see what works.
 If you have a Unicode version of wxWidgets, it's likely to use Unicode
 internally (e.g. for anything you type into a text field). That will get
 converted to a byte string (either by wxWidgets or by Python) by the time
 that it's passed to d.text, and it will probably use the locale's encoding
 to perform the conversion.
Ticket URL: <http://trac.osgeo.org/grass/ticket/291#comment:4>
