[GRASS-dev] no way to ID table columns outside of working mapset?
Moritz Lennert mlennert at club.worldonline.be
Mon Sep 8 12:07:24 EDT 2008
On 08/09/08 17:43, Michael Barton wrote:
> I'm working on a fix for vector attribute column selection in the wxGUI
> and discovered that I can't find a way to get the columns for an
> attribute table for a vector not in the current working mapset.
> v.db.connect and db.columns won't accept fully qualified map names. Is
> this something that needs to be fixed or is there a workaround that I
> didn't see?
Martin already gave you v.info, but db.columns is not related to a
mapset (not even necessarily related to vector attribute tables) and
thus works with any table,database,driver combination you give it.
And, v.db.connect does accept fully qualified in grass7:
GRASS 7.0.svn (nc_spm_06):~ > g.mapsets -p
user2 user1 PERMANENT
GRASS 7.0.svn (nc_spm_06):~ > v.db.connect -p mygeodetic_pts at sqlite
Vector map <mygeodetic_pts at sqlite> is connected by:
layer <1> table <mygeodetic_pts> in database
</home/mlennert/GRASS/DATA/nc_spm_06/sqlite/sqlite.db> through driver
<sqlite> with key <cat>
Can't test 6.4 right now...but I guess this is linked to Glynn's recent
changes.
Moritz
