[GRASS-dev] "Incompatible library version" errors
Maris Nartiss maris.gis at gmail.com
Tue Sep 9 01:35:07 EDT 2008
Glynn, You are correct about this error message, still IMHO it's good
to provide most likely failure case and a hint what to do next/how to
fix it. I numerous times have stumbled on "cannot write" errors and
friendly hint to run df lots of times has saved a day ;)
Maris.
2008/9/9 Glynn Clements <glynn at gclements.plus.com>:
> In general, error messages should only report what is known; they
> shouldn't attempt to guess as the underlying cause.
> E.g. if write() fails, then you know that write() failed. You don't
> know that it was due to insufficient disk space unless errno is set to
> ENOSPC. write() can also fail with EDQUOT (quota exceeded), EFBIG
> (maximum size of a single file exceeded), EIO (low-level I/O error,
> e.g. media fault, failed NFS server), and others.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
